ETZ leaking Brake Master Cylinder.
Re: ETZ leaking Brake Master Cylinder.
Postby Puffs » Wed Oct 21, 2020 4:16 am
Good you have it sorted Les, and thanks for sharing all this useful info!
Postby DAVID THOMPSON » Wed Oct 21, 2020 9:46 am
:smt006 i have found on my MZ bikes that brakes are best bleed by using a pump
and forcing the fluid up from the bottom so the air goes out
into the fill tank
do make sure the plunger in the master cylinder is open
and remove old extra fluid at the reservoir. at the top
they do not seem to want to get rid of air if done like most do a car
adjustment of pump do not get front lever to tight as it must be able to
pass fluid to and from the top tank
if wrong in hot weather if not open it can put the front brake on
and also may do this on the rear
your back brake locked up? check foot lever adjust system must be open to storage tank at rest
Postby Puffs » Wed Oct 21, 2020 10:39 am
Thanks David!
I do not have a bleed pump, but I never had big problems doing it the car way. Only on bikes I can do it all by myself.
Postby AlanJ » Thu Oct 29, 2020 7:41 am
Hi Guys,
A very interesting post, but just one small thing, when you anneal an item like copper you actually heat it till just red and then douse it in water ( not just let it cool)
Just for information, if you want to anneal aluminum, mark the alloy with a piece of white soap and heat it till the soap turns brown and that's it. Obviously using a blowlamp, it won't work in the oven.
Stay safe Alan.
AlanJ
Postby AlanJ » Thu Oct 29, 2020 8:09 am
Hi Guys,
Just had a thought about the copper, when I was smithing, we used to douse the copper in sulfuric acid/water to remove the black oxide on the surface,then in water to rinse it, so you would have to clean the oxide from the mating surfaces before reusing.
Alan.
AlanJ
Postby AlanJ » Sat Oct 31, 2020 12:00 pm
Hi Guys,
Have just had a look on/in Wikipedia, and according to them, nonferrous metals are heated and then quenched or left to cool. Now,I am writing this post because a previous post mentioned that in the annealing process of copper it is heated and allowed to cool, so, as I don't want to give anybody bum info
that's it, but I will mention that in 15 yrs as a silversmith, we always quenched on annealing.
Stay safe Guys, looks as though we are in for another lockdown, NASTY.
Alan.
AlanJ
Postby Puffs » Sun Nov 01, 2020 4:12 am
Thanks for all this info Alan!
Previous
