Running without lights or battery
Re: Running without lights or battery
Postby traderyoda » Mon Jun 07, 2021 8:50 am
I squeezed the points/condenser over on the left bottom of the schematic.
The problem with Rickmans is there's very little space on a Metisse frame to stuff anything. On other machines I've stuffed Tympanium units and supercaps in the airbox, but this machine has a very small airbox (much the same as the B441 Metisse) made of compound curves - no way to hide anything in there.
I did think about the nerve needed to flick that switch, which on this machine is between the seat and tank (where the oil fill would be on a MkIV frame). I can only imagine being the middle of the desert, having a plug load up, and reaching for it.
I'm thinking NiMH vs a supercap mainly based on current. Without any extra electronics, a NiMH pack will output around an amp of current. The field windings in the dynamo are 1.7ohm and I'd fear that a cap might dump in a ton of current and possibly burn up the coils. I don't know how much field energy it takes to fire up the motor. That'll take some experimentation down the road. I'll embed a tiny plug in the harness wired at 16-gauge so I can sort out the proper battery solution later. I have tons of NiMH, Li-ion, and LiFePO4 batteries lying around in the shop so I can play around with type and number of cells to find the best solution.
Were this a later model engine I would have found a magdyno vs this old style field coil unit. That's another option... I bet a later model magdyno would bolt right up and still be MZ ISDT.
traderyoda
Postby breakwellmz » Tue Jun 08, 2021 3:05 am
My old 250Supa Five had an `emergency ignition` position for starting when the battery was flat would yours work the same way without a battery? It does seems odd to have to have a battery fitted to a bike like yours.
Postby Puffs » Tue Jun 08, 2021 4:36 am
Postby traderyoda » Tue Jun 08, 2021 2:48 pm
Puffs wrote:Thinking about that, another comment: why is your battery on DF, bypassing that resistor? Why not just do away with that DF connection?
DF (I assume "F" means "field) to D- is what the MZ manual shows as power going into the field coils from the battery. I could certainly hook the battery to the D+ and D- connections. A 4-cell NiMH pack is 6V and would put a steady 1 amp or so through the field coils. Going to DF+ and D- with the same battery looks to me like over 3 amps going to the field coils. Since the field strength is directly proportional to the current the field would be roughly 3X stronger. Maybe that's what it'll take to get a strong spark... guess I'll find out. I don't want to overload the field coils and damage anything so I'll limit the current and see what I get. But if my math is right, MZ didn't seem to have any issue dumping 3+ amps into the field coils to get things humming. I'm cautious because I burned out an old airplane generator by flashing it with too much current. 1.7 ohms isn't much resistance.
Regarding supercaps, the ones I use have no issue cranking out gobs of current. Trying them here I'd certainly use a current limiter.
traderyoda
Postby Puffs » Wed Jun 09, 2021 3:12 am
Postby traderyoda » Thu Jun 10, 2021 7:13 am
It'll take some experimentation to establish a strong enough field to get it started. I think initially I'll use my DC power supply to gradually step up the current until I get a decent spark and then try starting. I have no experience with this motor or the side-float carb so I anticipate a slow learning curve. But I'll get it running and keep the forum posted.
Thanks all for your fantastic support!
traderyoda
Postby Puffs » Fri Jun 11, 2021 2:51 am
Well, thank you for this interesting topic & showing this most interesting bike!
Enjoy riding it!
Postby traderyoda » Wed Jul 07, 2021 2:37 pm
I love a good challenge and this project has it in spades.
I did install the dynamo and wired it roughly to see what I would get. I made a few errors in wiring and quickly sorted that. Result - nice crisp spark. I have a quick disconnect in the loop and hung a small battery pack on the circuit for about 10 minutes and that's all that was needed to energize the field coils. I doubt the battery needs to sit there at all really - just hook it up and kick.
I did update the diagram to correct my goofs.
Thanks to everyone for the help!
MZ Wiring Diagram_v2.pdf
(916.04 KiB) Downloaded 237 times
traderyoda
Previous
