keithcross wrote:Sorry to disagree cat, but the cylinder liner on the 660 engine is a cast iron one. Oversized pistons are available in 0.5mm and 1mm sizes. Aftermarket pitons are available in 102mm (2mm oversize = 686cc) and 105mm (5mm oversize), but the 5mm pistons require machining to the crankcase and can only be fitted (or so I am told) if teh crank is stroked as well. This conversion gives 727cc
Users browsing this forum: No registered users and 235 guests
