Switchgear
Switchgear
Postby Uncle Nick » Wed Nov 29, 2017 5:40 pm
Hi all, as it's freezing in the garage I've brought the (non-working) switchgear into the house to strip. I've separated and cleaned the contacts etc, which were very mucky with a thin black grease material covering everything. I've cleaned that off and lightly sanded the contacts, which appear ok. I suspect that the black stuff may have been a light oil that has protected the contacts but then ground accumulated dirt into a paste, until the contacts were insulated and stopped the switch from working.
So my question is, what type of oil or grease (if any) should I use on reassembly?
Thanks.
Uncle Nick
Re: Switchgear
Postby DAVID THOMPSON » Thu Nov 30, 2017 2:43 pm
something that does not conduct electric
but no wd 40 or 3 n1 oil
Re: Switchgear
Postby Uncle Nick » Thu Nov 30, 2017 3:01 pm
Yes I think that it may be WD40 to blame.
I wonder if contact cleaner spray would be any good?
Uncle Nick
Re: Switchgear
Postby DAVID THOMPSON » Thu Nov 30, 2017 11:07 pm
now that tv tunners are all solid state the good tuner cleaners are all gone
any one got any ideas
Re: Switchgear
Postby Blurredman » Fri Dec 01, 2017 3:52 am
Vaseline or Dialetic Grease. 8)
1987 MZ ETZ300 - 38,000 miles
Re: Switchgear
Postby DAVID THOMPSON » Fri Dec 01, 2017 11:34 am
Vaseline + BIG MESS
Re: Switchgear
Postby Uncle Nick » Sat Dec 02, 2017 6:55 am
Thanks for the help guys. I've put a thin smear of silicon grease on the moving plastic parts but would like to try and prevent corrosion of the brass connections as well if possible.
I've never heard of a dielectric grease, I'll have to have a Google!
Uncle Nick
Re: Switchgear
Postby DAVID THOMPSON » Sat Dec 02, 2017 8:30 am
dielectric grease a common use is when mount a power transistor to a heat sink
but not wanting an electrical connection
Users browsing this forum: No registered users and 260 guests
