TS 250 Fuel Mix
TS 250 Fuel Mix
Postby TheHoff » Wed Jul 16, 2014 3:49 pm
Please confirm exact fuel mix for the TS 250. How many cups to every litre of fuel, and do you measure to the higher line in the fuel cup or the lower line??
TheHoff
Re: TS 250 Fuel Mix
Postby MichaelTorre » Wed Jul 16, 2014 8:25 pm
What year is your bike ?
M
MichaelTorre
Re: TS 250 Fuel Mix
Postby TheHoff » Thu Jul 17, 2014 12:23 am
Hello Michael,
The bike is 1978. Also I got caught in the rain last night, after putting fuel in (2 cups in 10 litres) the bike cut out and back fired/popped 4 times on way home?
Not sure if mixture caused this or doesn't like wet?
Cheers
Hoff
TheHoff
Re: TS 250 Fuel Mix
Postby stinkybob » Sat Aug 02, 2014 9:07 pm
You're going to hate me for this but I don't use two stroke oil at all anymore. For the last ten or so years I've been using diesel at a ratio of one liter diesel to one gallon of petrol and it works better. It keeps the engine internals cleaner and creates far less exhaust clogging and piston carbon. I also don't use that ghastly BVF carb abomination on my engine anymore. I have a modified 1-1/2" SU which works FAR better. Also I have replaced my coil with a car coil and have adapted Suzuki GT380 points to it which work a thousand times better than the bog standard MZ shite. I also run two condensers and use long spark plugs to increase compression. I shall run away and hide now before the proper MZ Nerds come for me with pitchforks and burning torches.
stinkybob
Re: TS 250 Fuel Mix
Postby paulatradese-6 » Sun Aug 03, 2014 10:20 am
I have been thinking of doing the SU carb mod, since seeing it on pigeons website. http://pigeonsnest.co.uk/stuff/photos/mz.html
He used a SU HS2 which is 1 1/4" I think.
paulatradese-6
Users browsing this forum: No registered users and 56 guests
