what other forks fit a ts150
Postby flatyre » Wed Mar 05, 2014 2:01 pm
Hi all, the forks on my TS150 are a bit pitted so was wondering if the tubes can be replaced or would it be cheaper to buy a set of second hand forks off a more common bike? cheers
flatyre
Re: what other forks fit a ts150
Postby pmorris4562 » Thu Mar 06, 2014 6:03 am
ost2rad probably have replacement stanchions for less than the cost of re-chroming.....
Or you could try filling the pits with Araldite, and smoothing down if they aren't too bad. The stanchions will be hidden by the gaiters anyway. :wink:
1993 SilverStar, 1991 ETZ301
pmorris4562
Postby arry_b » Thu Mar 06, 2014 7:03 am
Check the fork tube diameter.
If they're 35mm, the tubes off of any ETZ or a TS250/1 will fit. Some early 125/150s have 32mm forks, but almost all of the ones you'll find are 35mm.
EBay should be your friend, or if you're in the UK, hunt out your local MZRC section. This is the sort of thing most MZedders have in their sheds getting in the way.
arry_b
Postby flatyre » Sat Mar 08, 2014 5:31 am
cheers guys i'll measure them up, they aren't too bad now they have been cleaned up, i'll give the araldite a go on the worse bits.
flatyre
Users browsing this forum: Google Adsense [Bot] and 38 guests
