Mastiff Speedo/ Tacho bulbs
Postby Silverstripes » Fri Oct 19, 2012 7:11 am
Hi guys new member here. :smt006
Whilst I am a new member to this site I have had my Mastiff for 4 years. Had a few electrical issue I have resolved and I do all my own maintenance. Its a great little bike and compliments my other bike which is a GL1800 Goldwing :shock:
The reason for this post ois that my Tacho and one speedo bulb has blown and I want to replace them. How on earth do you removed the lower domed shell of the speed and tacho. I cant see any screws and I have tried levering with screwdriver but both will not budge.
Any ideas please :D :D
Regards
Adrian
Silverstripes
Re: Mastiff Speedo/ Tacho bulbs
Postby Silverstripes » Fri Oct 19, 2012 9:40 am
Ok Problem solved :D
I found a web site with an exploded view of the speedo and rev counter. There is a small screw in the bottom of the housings. I revoved the headlight and then you can see the screw. The rev counter is in the middle and seedo is offset.
All now working.
Regards
Adrian
Silverstripes
