Removing 301 Kick Start
Postby stuart-glos » Mon Jul 02, 2012 1:03 am
I have failed to remove the kick start from my 301 project.
I have loosened the lock nut and freed off the washer, sprayed the whole thing with WD40 and tried to ease out the cotter pin with a hammer but it's stuck.
Any suggestions please?
thanks
stuart
stuart-glos
Re: Removing 301 Kick Start
Postby rodge70 » Mon Jul 02, 2012 7:08 am
i find a bit of heat from a blow torch usualy helps to shift the stubborn stuff,good luck
rodge70
