660 Carb rebuild parts question
Re: 660 Carb rebuild parts question
Postby breakwellmz » Mon Dec 06, 2010 4:10 pm
Christmas cracker screwdriver or `Land of the giants`(remember it?)hand? I`ve always wondered where the idle mixture screw was on my `05 Mastif-Never needs much choke, even on the coldest of days,sooty exhaust AND only ever a maximum of 55 mpg.Is it REALy between the carbs?
Postby Fluffy_Dog_1018 » Mon Dec 06, 2010 5:25 pm
Yup, I use one like that. At first I thought your's was a regular screwdriver and that you were a giant!
Somthin ain't right.
1982 Yamaha Maxim SOLD
2001 Suzuki SV650 SOLD
2001 Kawasaki Concours SOLD
1983 Honda CB650SC SOLD
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby Fluffy_Dog_1018 » Mon Dec 06, 2010 5:30 pm
It is on the front of the left carb close to the intake boot. From the side it looks like a metal bar, but if you get down and look (or use a small mirror) you will see the screw up in the tube. Turn it in (CW) till it seats (go easy) and then back it out (CCW) as many turns as you need (spec is 2.5, but mine seems to run best at 4). For you maybe best to start turning it in until engine stumbles and then just back it out a bit? Good luck.
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby Fluffy_Dog_1018 » Sun Jan 02, 2011 9:16 pm
2001 Traveller. For anyone else going down this road... Here is a shot of the carb kit I got off of eBay. Worked fine. Only issue I had was I had to file the upper neck of the needle seat down 1 mm for the needle to seat properly.
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby breakwellmz » Mon Jan 03, 2011 3:10 pm
Hi.What exactly is in the rebuild kit?Cheers-Martin.
Postby Fluffy_Dog_1018 » Mon Jan 03, 2011 4:56 pm
Hi Martin, there are a few listed on eBay all the time. Here is what they include. Note I did not use the jets that came with the kit... stock jets are 165 right, 130 left, and 48 pilot.
KIT INCLUDES
BOWL GASKET; 2 SLIDE NEEDLES AND CLIPS; FLOAT NEEDLE AND SEAT, EMULSION TUBES; #135 MAIN; #110 AND #48 SLOW JET; AIRSCREW AND SPRING AND MISC PACKING AS SHOWN
Good luck.
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby breakwellmz » Fri Jan 07, 2011 11:42 am
Thanks for that mate.Cheers-Martin.
What size is the fuel line for the Skorpion?
Postby pwillikers » Sat Jan 08, 2011 8:01 pm
What size is the fuel line for the Skorpion? I scoured the manuals and searched here but didn't find any information. I bought some 1/4" and it's a tad large. I see there is both 5mm and 6mm available.
Thanks.
Paul
'96 MZ Skorpion Sport - track bike extraordinaire
'99 BMW R1100S
'00 Suzuki SV650
'09 Buell 1125cr
pwillikers
Postby Fluffy_Dog_1018 » Sat Jan 08, 2011 10:19 pm
I've used Motion Pro fuel line with a 3/8" or 5mm i.d.
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby basser23 » Sun Jan 09, 2011 8:25 am
Not to question your measurements,but a 3/8 would be too large almost 10mm ,5mm is about 3/16" :)
basser23
Postby Fluffy_Dog_1018 » Sun Jan 09, 2011 1:35 pm
Duh, I only made it 9 days into the new year without making a mistake. Actually that is a record for me! Yes 3/16 or 5mm i.d. BTW I used Motion Pro gray on mine.
John
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Postby basser23 » Mon Jan 10, 2011 9:25 am
Funny! Good to know someone who also makes mistakes...I know mine are numerous this year already....:)
basser23
Postby DAVID THOMPSON » Mon Jan 10, 2011 10:10 am
my dad said people that do not make mistakes .
usually don't do anything ...
my thing is i just try not to admit i made any
and i have a very good week when i do not get blamed for the mistakes of others
ATV Complete Carb Rebuild Kits Yamaha 02-05 YFM660 Grizzly
Postby jacie flatt » Thu Jan 12, 2012 4:42 am
ATV carb rebuild kits. Complete kits rebuild original equipment carburetors. Each kit contains all necessary gaskets, O-rings, float valve and jets.
jacie flatt
How do you fix your Yamaha raptor 660 carb it keeps bogging
Postby jacie flatt » Thu Jan 12, 2012 4:44 am
It sounds like your carbs are set wrong. You need to adjust your air fuel mixture screw on the bottom of the carbs by the bowl. You won't need to take the bowl off to get to the adjustment screw. Turn the screw all the way in til lightly seated then then count the turns out. Set both carbs at 2 turns out. When it bogs down pull the choke and if it runs better then you are not getting enough fuel. If it gets worse then it is getting to much fuel.
jacie flatt
Previous
Users browsing this forum: No registered users and 185 guests
