MZ1000 ST Front Discs - Spec or source
Postby Shiny » Thu Oct 05, 2017 2:55 pm
I need to replace both discs and have been finding it a bit of a struggle identifying replacements. Can anyone help?
Shiny
Re: MZ1000 ST Front Discs - Spec or source
Postby DAVID THOMPSON » Fri Oct 06, 2017 10:02 pm
the ebc catalog stinks any more finding this took over 2 hours and did not allow me to cut and paste
MD855x and MD855xc 320 mm dia fits no other bike i could find it is a floating rotor
page 640 in the 2017 ebc big book over 800 pages in my pdf reader its page 642
Postby MJ310 » Sat Oct 07, 2017 5:10 am
When you find the correct type can you post it here please?
I thought I had it on my list of compatible bits but I don't, sorry.
MJ310
Postby DAVID THOMPSON » Sat Oct 07, 2017 10:43 am
this is so rare it will probably be hard to find even if you know the numbers
Postby dandywarhol » Sun Oct 08, 2017 11:35 am
It looks very similar to a Yamaha SZR660 disc. Check the offset............
https://www.s3performance.com.au/front- ... SS7591.E20
Whale oil beef hooked
dandywarhol
Postby MJ310 » Mon Oct 09, 2017 3:57 am
MJ310
Postby MJ310 » Mon Oct 09, 2017 4:06 am
Or this.
http://www.speedaddicts.com/motorcycle/ ... tor-md855x
From what I can find it's an MZ only fit but MandP in south wales lists it as the same disk as a Kawasaki GPZ 660r, GTR 1000 and GPZ 750. I cannot believe that MZ has a disk that is specific to them and didn't use a already available disk (as it did for everything else). Kawasaki disks will certainly be cheaper (as long as they fit). Good luck with your search, If I find out anything more I will let you know.
MJ310
Postby dandywarhol » Mon Oct 09, 2017 5:08 am
MJ310 wrote:Or this.
I noticed these too but they only have 5 mounting holes
dandywarhol
Postby handsomejackuk » Mon Oct 09, 2017 10:33 am
who was i chatting to in abergavenny yesterday ?
Postby MJ310 » Tue Oct 10, 2017 3:48 am
I think that's just a generic picture because the part number is correct, MD855e and ex. I emailed ebc yesterday and got the full spec of the disks and they confirm that is the MZ1000 series is the only fitment for that disk. Below is the reply I got from EBC.
We will have discs with similar measurements but not exactly the same.
Kind regards
Mike Cooper
Data & Technical Adviser
01604 583344
Sent: 09 October 2017 14:58
To: Mike Cooper
Subject: RE: General enquiry from EBC Brakes Direct
Thank you very much, are there any other disks with the same spec?
Cheers
Mick
On 9 Oct 2017 2:53 p.m., "Mike Cooper" <Mike.Cooper@ebcbrakesuk.com> wrote:
Hello the offset for this disc is zero-
Products
Prefix Part No Type heat treated OD Finished Thickness ID Off set bolt hole PCD No of bolt holes bolt hole dia Hole condition Rotor Variants Pattern
MD 0855 Floater Yes 320 5 64.2 0 80 6 8.5 Plain
If this is not correct we may have other options available if you can provide me with the dimensions shown above but please note we do not make one off specials.
MJ310
Postby MJ310 » Tue Oct 10, 2017 3:52 am
handsomejackuk wrote:who was i chatting to in abergavenny yesterday ?
It was me, nice to have met you.
MJ310
Postby Thorsten-aus-SO » Tue Oct 10, 2017 1:38 pm
MD855x does fit.
I tried them.
Kind regards
Thorsten-aus-SO
Return to 1000S
