ECU needed
ECU needed
Postby johnsb » Fri Aug 29, 2014 8:15 am
Hi every one I am desperately looking for a new or used ECU for my MZ 1000 SF. But S or ST will be fine. My one is broken, Graham's have cleared the fault codes but the fans are on all the time, the speedo and rev counter do not work and feels as though it's in safety mode. There are no new ones available from the factory Graham's do not have one and they cannot re program it as they cannot get the program. Can anyone help please, I have a Mint 1000SF that cannot be ridden.
johnsb
Re: ECU needed
Postby den » Fri Aug 29, 2014 11:56 am
http://www.powercommander.com/powercomm ... USB&notes=
unsure wether its a direct replacement or maybe they can look at your old one
den
Re: ECU needed
Postby den » Fri Aug 29, 2014 12:15 pm
could you ask grahams is he could copy a program on a donor ecu?? im sure someone here would help you out..like clone it
den
Re: ECU needed
Postby den » Fri Aug 29, 2014 12:57 pm
also found this quote in the middle of a forum about what fits what..
Aside from price, the statement in the title is not correct. ** MZ 1000 S SF ST ECU engine control ECU from a MZ1000S is only tuned for a MZ1000S. although the SF and ST runs it, but just not right. This lesson in S-ECU had Karsten (MuZMan56) and I last year at Dr. Faber in October at our Rhine -. / Mosel Tour Karsten had a S-ECU in his SF in it, which was not right (throttle response, driveability slow, jerking, ...). At SF / ST a camshaft with a different offset than the S is fitted. This was very surprising and at the same time informative for us. Although simply replace the ECU as times goes forth from the installation, but of the vote here, it does not fit. Notice this just so on the edge, if someone pays € 1,000 for it and wonders following, why his SF or ST as " unusual "running. Whoever wants to know exactly, well, just call at MZ-Faber. Greetings Marco
den
Re: ECU needed
Postby iceman » Fri Aug 29, 2014 2:05 pm
German E-bay has one
http://www.ebay.de/itm/MZ-1000-ECU-elec ... 19f2da9cc4
Der Verkäufer ist für dieses Angebot verantwortlich.
Artikelmerkmale
Artikelzustand:
Neu: Neuer, unbenutzter und unbeschädigter Artikel in der ungeöffneten Originalverpackung (soweit eine ... Mehr zum Thema Zustand
Motorradmarke:
MZ/MuZ
Artikelnummer:
3548008005, 3548007005, 3548006005, 3548005005
Motorradmodell:
[b]MZ 1000 S, MZ 1000 SF, MZ 1000 ST
[/b]
Weiterer Artikelnummer:
9017199
Teilehersteller/Anbieter:
Sagem
John Lennon
iceman
Re: ECU needed
Postby Chalks » Sat Aug 30, 2014 12:05 am
There's a company in Oxfordshire called Electrex that repair ECU's, usually around £150
Tel: +44( 0 )1491 682369
Good luck.
Chalks
Re: ECU needed
Postby MJ310 » Mon Sep 15, 2014 5:00 pm
Please keep us updated on your ECU, I have an SF (running perfectly at the moment) and if I have a problem it would be nice to know there is a solution.
MJ310
Return to 1000S
Users browsing this forum: No registered users and 141 guests
