boilermaker wrote:Mach
A thank you for the info might be nice.
Mach IV wrote:Yanno,parts other than factory stuff,like keys,filters and the like.
I'd like to know the K&N part number for their air/oil filter,chain and sprockets would be another good one.
More options the better.
Which other bikes use the same.
The Japanese stick coil interchange,etc.
There is very little on the 1000 series that is specifically MZ. The brakes etc are standard jap items as fitted to a number of jap bikes. The forks are the same Marazocchis as fitted to my wifes Ducati and the Sachs rear suspension is as fitted to some Aprilias. The Sagem/JC engine management system is as used on at least five other makes of machine. The oil filter is a K & N HP 1002 Brake pads (front) Ferodo FDB557 (rear) Ferodo FDB 2111 The plug coils are as fitted to most of the Citroen/Renault/Fiat/Peugot V6 engines and some of the Triumph triples. The air filter is the only item that I have not found an alternative for. There are too many items to list here and If you would care to join the Yahoo autos group then you will find a complete database under MZ 1000.
George
