Steering lock/ignition switch.
Postby boilermaker » Sun Aug 21, 2011 10:02 am
To All
any of you out there with a ZADI Q933 Type ignition switch/steering lock (this probably means all of you) please check the tension on the shear type security mounting bolts. A potentially lethal scenario has arisen when the lock barrel/unit drops almost through the top yoke and jams itself between the top yoke and the frame extension that supports the fairing etc. for further info please read my post on the 660 section of this forum.
boilermaker
Return to 1000S
Users browsing this forum: No registered users and 126 guests
