Bearing Leak.
Bearing Leak.
Postby TheQK1 » Tue Jan 18, 2011 7:13 am
Hi again
Best for 2011 for all.
I have noticed a Bearing leak on the gear lever that go into the engine. Is this damage on the bearing or is it a seal maybe?
Can I get the part from a local or any bearing shop or is it specific to MZ and I need to order it in?
Regards
Werner
TheQK1
Re: Bearing Leak.
Postby Ally » Tue Jan 18, 2011 7:34 am
Hi Werner
the following link is the parts diagram from Graham Motorcycles....
http://www.grahamsmotorcycles.com/MZ1000/Fiche%20Spare%20parts%20MZ1000S.pdf
the bearing and seal sizes are generally listed
ally :)
Ally
Re: Bearing Leak.
Postby LWS66 » Tue Jan 18, 2011 8:31 pm
Your on the right track, either get the dimensions of the seal prior to pulling cover, or pull the cover and the seal, take it to your local supplier and they can get you the equivelant seal. I do it all the time for bikes and cars, and it's a heck of alot cheaper.....for the same quality. :-D
LWS66
Re: Bearing Leak.
Postby TheQK1 » Wed Jan 19, 2011 2:51 am
Thanks Guys, will do.
Regards
Werner
TheQK1
Return to 1000S
Users browsing this forum: No registered users and 143 guests
