Mz etz 251 problem..
Postby Sj0rre » Mon Jul 13, 2015 4:57 am
Hello I'm a new member from Sweden and I have a problem with my mz etz 251.
It won't Rev over 1000/1200 rpm i give it full throttle but it just won't Rev what can the problem be?
Sj0rre
Re: Mz etz 251 problem..
Postby DAVID THOMPSON » Mon Jul 13, 2015 1:35 pm
look in the back of carb with the rubber boot removed
and see if it is actually moving the slide up in the carb
may have a broken throttle cable or it has come loose at carb or handle
may have pulled the brass end off the cable
you should always carry a spare clutch and throttle cable
unless you like walking home
they work good but i learned long ago it will always break when your max distance from your spares
Postby Sj0rre » Mon Jul 13, 2015 4:29 pm
The throttle cable is working, took it apart and noticed that the contact breaker is worn-out so I ordered a new one.
Sj0rre
Postby DAVID THOMPSON » Mon Jul 13, 2015 4:54 pm
yes points do not last forever.. be nice if they did
Postby Sj0rre » Mon Jul 20, 2015 8:42 am
So got new points and installed them but still no difference
Sj0rre
Postby vicar » Mon Jul 20, 2015 11:32 am
Can you make a little video with your phone showing what happens when you twist the throttle it would help if we could hear the engine
vicar
Postby Sj0rre » Mon Jul 20, 2015 1:10 pm
Well it looks like a seal is bad and the engine is getting filled up with gas..where can I order a set of seals gaskets an bearings..
Sj0rre
Postby therealche » Mon Jul 20, 2015 3:40 pm
therealche
