Piston/Rings
Piston/Rings
Postby kevmead » Sat Feb 22, 2014 7:29 am
Hi there, could anyone advise me the best place in uk to buy ETZ 251 standard Piston/Rings from.
Cheers
kevmead
Re: Piston/Rings
Postby therealche » Sat Feb 22, 2014 9:59 am
http://www.themzshop.co.uk/product/pist ... ton-rings/
(Oops just noticed you wanted a piston too, and I dont think they have one. Burwins always worth a ring, or follow Arry's advice below!)
therealche
Re: Piston/Rings
Postby arry_b » Sat Feb 22, 2014 1:06 pm
Or (from outside of the UK, but that's never been a problem):
ost2rad.com
A piston kit, complete with rings, gudgeon pin etc, delivered to the UK will be around 45 Euros - around £37 quid.
arry_b
Re: Piston/Rings
Postby therealche » Sun Feb 23, 2014 4:59 am
Yup Ive used Ost2rad too and had great service.
therealche
Re: Piston/Rings
Postby Blurredman » Sun Feb 23, 2014 6:01 pm
Does no one here use mz-b.net??
Re: Piston/Rings
Postby therealche » Mon Feb 24, 2014 7:08 am
Not used them since they went to Hungary. Seem remarkably cheap and having had some Polish spares that were only worth sticking in the scrap bin I am a little wary
therealche
Re: Piston/Rings
Postby Blurredman » Mon Mar 03, 2014 7:59 am
I buy an awful lot of stuff from MZ-B in Hungary. Sure some parts were a little off, for example the side stand. Which I had two of which really weren't strong enough at all. Ended up buying an original. But everything else has been pretty good! They're only going to list the same things as MZ-Shop and Ostob2b.
Things are cheap, but then you should choose the items listed made in germany, rather than tailand or india. Worth the little extra for better quality provisions.
