new member
new member
Postby ozzieowl » Sat May 17, 2008 10:59 am
hello my names john its my first mz baghira got it yesterday wont start today good start .
ozzieowl
Re: new member
Postby DAVID THOMPSON » Sat May 17, 2008 8:42 pm
we get the it will not start problem a lot ....when you get it sorted out you will like it
Re: new member
Postby el-mar » Sun May 18, 2008 1:30 pm
good luck and welcome here
el-mar
Re: new member
Postby Lamaha » Sun May 18, 2008 4:23 pm
First stop is check your battery is good,
Had this trouble with the XT660 and a good quality battery or even good charge will solve it.
Its a big lump to turn over, but as said previously once your up and running they are a great ride.
Best of luck and welcome.
Lamaha
Re: new member
Postby Sue » Mon May 19, 2008 5:47 am
Hi John, had similar problem after 4 days of riding. Mine turned out to be a break in wires in the loom, and then a flat battery. Now sorted and think my Baghira is awesome :-D You will really love it once sorted.
Sue
Re: new member
Postby scout18 » Mon May 19, 2008 7:32 pm
90 percent of your electrickery is bad ground connection and then dirty connections in general. A little wire brushing and dialectric grease goes along way towards reliabilty. Only change one thing at a time . Good luck
scout18
Re: new member
Postby Anna » Wed May 21, 2008 6:04 am
And the Baggy's not the first MZ to suffer from bad earthing. Had a similar problem on my (then nearly new) Saxon 2-smoke too.
You'd think they'd've sorted it by now...
But like the guys have said John, once it's fixed it's a MARVELLOUS bike. Do enjoy. I'm quite envious of all you Baggy owners and am starting to miss mine terribly, it's only about 4 years since I sold it...
Anna
