MZ 125 Supermoto Rear Sprocket
Postby MarkfromBelfast » Fri Jun 07, 2013 5:43 am
I need some help if possible please, I need a rear sprocket for my bike but mechanics are having trouble sourcing the part.
Dimensions are ...
Centre hub 96mm.
5 bolt holes with 8 mm bolts, hole size 8.5 mm.
Bolt spaces bolt to bolt 6.3 mm.
If anybody can sell me a good condition spare or help me locate this part new it would be a great help.
Thanks.
MarkfromBelfast
Re: MZ 125 Supermoto Rear Sprocket
Postby DAVID THOMPSON » Fri Jun 07, 2013 11:08 am
german sprocket company ESJOT
49 tooth stock 52 makes it work better with a big rider or in hills
http://www.esjot.com/en/
http://www.esjot.com/en/sprockets-and-c ... 5&baujahr=
which wheels do you have alloy or spoke
READ BELOW
this post about 125 sprockets
including the last part at bottom of page
viewtopic.php?f=4&t=49
Postby stephendacosta » Wed Jul 31, 2013 10:04 am
I saw rear sprockets available at http://www.mzsimson.de/ in Germany
Front sprockets available through JT sprocket dealers. #JTF558.13 or 14 or 16
the last two digits indicate how many teeth. 16stock.
JT also has sprockets that fit both front and rear if you convert to a 520 chain size.
Stephen DaCosta
stephendacosta
Return to Wanted
Users browsing this forum: No registered users and 180 guests
