lost key
lost key
Postby tonyc » Fri Jul 20, 2012 3:44 am
How do I go about getting a new key and barrel? I have lost my keys!
A
tonyc
Re: lost key
Postby radiograf » Fri Jul 20, 2012 4:31 am
Give us a clue, what bike!
radiograf
Re: lost key
Postby DAVID THOMPSON » Fri Jul 20, 2012 6:15 am
when they were new there was a cut number on the plastic that joined the 2 keys
if your lucky and have that number a lock smith may be able to cut you a new set...
if you go looking at a breakers here is the list of bikes using this type keys
and a bunch of info on keys
DAVE
viewtopic.php?f=3&t=2596&p=14824&hilit=keykey#p14824
Re: lost key
Postby tonyc » Sat Jul 21, 2012 3:36 pm
The bike is an ETZ 251 made in 1992
tonyc
Re: lost key
Postby DAVID THOMPSON » Sat Jul 21, 2012 4:26 pm
try Gunther Six in the dealers section
viewtopic.php?f=18&t=4230
there may be a cut number on the bike some where
or he may have the lock parts
or if there is a locksmith in your area he may be able to make a set
Re: lost key
Postby radiograf » Sat Jul 21, 2012 4:30 pm
If its the sidepanel lock see my post: http://mzriders.com/viewtopic.php?f=20&t=5913&sid=049b2b916c9320b36d44620ae4514373,
if its the ignition key they are all the same, and are available on ebay.
radiograf
Re: lost key
Postby therealche » Sun Jul 22, 2012 5:19 am
radiograf wrote: if its the ignition key they are all the same, and are available on ebay.
Unfortunately at some point MZ decided that there were nasty people that might try to steal MZs and fitted a proper ignition key/lock set. Mind you you could still use a screwdriver, you just had to hit it harder 8)
therealche
Return to Wanted
