Wanted: Parts for Tour
Postby Tuesday10july2012 » Thu Jul 12, 2012 12:41 am
I just bought an MZ Tour and it needs some TLC. The turn signal relay isn't functioning. I need one! Headlight is cracked. I got one on the way. The brake pedal won't activate the brake light. Is there an adjustment I can make or is the switch kaput? It appears to pressure activated by the brake fluid. My rubber bits are worn out. I need footpeg rubber and the chain slider is hanging in ribbons. The bike has no horn! Before I start rummaging and cobbling, I thought I'd try to find some Genuine Used MZ Skorpion Tour Parts. Help me resurrect this bike as intended, or God Forbid, I'll be forced to unleash some unholy Frankenstein!
Tuesday10july2012
Re: Wanted: Parts for Tour
Postby radiograf » Thu Jul 12, 2012 2:33 am
Check out the following strings in the 660 part of the forum: baghira rear chain guide,
rear brake light not working,
banjo brake switch,
skorpion swing arm chain protector.
As for the horn and indicator relay, take them to your local dealers and they shold be able to source a pattern replacement.
Is the headlight round or square? A 7" round car one should suffice, the square type in the fairing may be more of a problem. I believe that there is a string on this in the forums.
radiograf
Postby droy » Thu Jul 12, 2012 8:30 am
Tuesday
Sent you a PM
Doug in NJ
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Return to Wanted
