ETZ 251 Side panel
ETZ 251 Side panel
Postby tonyc » Wed Jan 11, 2012 4:03 pm
I need a side panel (RHS) for a 1995 ETZ 251. I am trying to fit a cigarette lighter type socket, and I need a spare to practice on before I start cutting the one on the bike to pieces! tony dot corkin at aol dot com thanks.
tonyc
Re: ETZ 251 Side panel
Postby radiograf » Thu Jan 12, 2012 2:19 pm
Instead of cutting a side panel, check out the cross member under the tank in front of the seat. You may be able to push one into there, on the left side, and run the cables through to the battery on the right. Don't forget to put a fuse in the circuit.
radiograf
Return to Wanted
