Wanted: Carborator Bowl for Baghira
Postby Tangletard » Wed Dec 08, 2010 9:39 pm
I am looking for the float bowl from the carborator on a Baghira Black Panther. I managed to strip the drain plug screw on mine. Before I try to re-tap or and heli coil the bowl, I would like to try and replace it.
Contact me at
email: esangle at gmail dot com
phone: five one two - six five nine - one one five two
Thanks,
Ted
Tangletard
Re: Wanted: Carborator Bowl for Baghira
Postby DAVID THOMPSON » Thu Dec 09, 2010 10:28 am
if you do the heli coil be sure to put a gas proof sealer on it at install so it does not leak
Postby Tangletard » Thu Dec 09, 2010 9:29 pm
Dave,
Thanks for that tip. I had not considered that but now that I think about it, I see that the heli coil will likely let fluid pass.
As I said, I prefer to replace the bowl.
Ted
Tangletard
Postby hb7 » Sat Dec 11, 2010 1:45 am
Carb bowl from the yamaha xt600 1995 is the same.
yamaha parts has them.
All the best,
Henri Baccouche
moto-science : the ducati mirror specialist ™
http://moto-science.com/
323-933-1366
skype shb777
hb7
Postby Tangletard » Mon Dec 13, 2010 10:16 pm
Henri,
Thanks. I will look for it. Hopefully it is not an arm and a leg.
Ted
Tangletard
Return to Wanted
