WTB: A Few Skorpion Bits
Postby Road Weazel » Mon Mar 08, 2010 2:14 am
Greetings. I'll be needing a few pieces for my Skorpion. It's not a 'Tour' and it's not a 'Replica'. Not sure what other models there are. I'll add/change the list as I dig deeper...
First up would be:
Tail section, Race Only is fine, or if it's stock I'll need the rear seat as well. I have the front seat.
Clutch perch on the handlebars
Windscreen
Performance exhaust, mid-pipe only is fine as I have a few spare mufflers laying around
Shift pedal with heim joint
Right and Left handlebar switches
I'm in AZ, USA and within the USA would be preferred to keep shipping costs reasonable.
Thanx.
Weazel
Road Weazel
Re: WTB: A Few Skorpion Bits
Postby droy » Tue Mar 09, 2010 7:55 am
Weazel,
What you have is a Skorpion Sport, I'd say 1996. If you can't find some used body work it's available in the UK new or Beasley Composites (look under Ducati) for fiberglass race stuff (you'll need to cut out a section so you can use the stock seat). Search Gear Shifter and you'll find some options to convert to a GP pattern. For the perch your likely better off replacing the entire unit with a universal from Motion Pro or some other bike. Gustafsson Plastics for the wind screen.
If you want original stuff it's mostly available from the UK importer.
Good Luck
Doug in NJ
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Return to Wanted
