Skorpion Parts Needed
Postby Team222 » Tue Apr 17, 2007 7:29 am
1. Shop Manual or source to buy one
2. Ignition with Key (new or used ok)
3. Fuel Tank Gas Cap that fits Ignition Key (new or used ok)
Note on 2 and 3: Were these parts also fitted other manufacturers bikes...if so ..which ones so I can check dealers or parts sources.
4. Someone in USA that can help me make my X racer street legal. I have most of the street parts. I live in Pennsylvania.
Thanks so much
Mike Barone
Team222 = 2 ole, 2 fat & 2 slow
My MuZ lives near Harrisburg, PA USA
Team222
Postby basser23 » Tue Apr 17, 2007 9:11 am
I had the same issues with my x race bike. Mine had an ignition switch and no key,also it was wired to a toggle switch for ignition.NOT legal for street use. I found that a switch from a Guzzi was the same. Do you have
the switch mounted or is it missing? My gas cap opens with a screwdriver
(flat blade) if necessary.
The manuals were available through mzna,but outta business now.They
really only were photo copies and a parts book.Some wiring diagrams
etc are avail through MZOG@yahoo..
In PA I guess you need lights, turn signals, reflectors etc...pretty easy
stuff..my speedo does not work so I hooked up a digital bicycle speedo
works great...
The owner I bought mine from finally found a key for the ignition.....so ididn't have to mount the Guzzi switch..I'll see if i can find it...
Chip
Postby Team222 » Thu Apr 19, 2007 3:54 pm
Thx.....lots
Mike
basser23 wrote:Hi,
works great...
Chip
Team222
Postby basser23 » Thu Apr 19, 2007 4:14 pm
Mike,
If you go to MZOG@yahoo.com and join,you'll have access to manuals.
Look in the files section, most are in pdf format.just pulled a carb manual
from there...lots of good info too..
Return to Wanted
