Skorpion Sport clutch pedal
Postby rd400racer » Mon Sep 16, 2019 6:19 am
I've got a race in 2 weeks and it appears that the existing pedal was bent at some time and is at quite an awkward angle. It will do, but I'd sure like one that is normal. I'm afraid if I try to bend it back it will break and then I'm really screwed. Thanks
rd400racer
Re: Skorpion Sport clutch pedal
Postby droy » Mon Sep 16, 2019 8:45 am
Foot gear shift? That's steel and can be bent back into shape, maybe with a little heat.
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby rd400racer » Mon Sep 16, 2019 9:49 am
Yep, foot gear shift. Man, it sure looks like aluminum to me.
rd400racer
Postby droy » Mon Sep 16, 2019 12:52 pm
the stock one is steel. Pull off the little rubber cover on the end of the shifter and scratch a bit off and check.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby DAVID THOMPSON » Mon Sep 16, 2019 2:55 pm
MY 97 Traveller is ALLOY just tested with a magnet
its the lever you work with your foot
other bikes have levers that will fit at transmission shaft
but i think that makes the shift pattern backwards
some like that for racing
Dave
Postby Puffs » Tue Sep 17, 2019 5:17 am
Right, it's a rear-set gear shift lever.
But also an alu alloy you can bend. Heat it while testing how stiff it still is, if you're warm enough you feel it gives with just a little pressure.
Or just rig something from a bar & a bolt going sideways.
PS: yes, I believe common racing currently is 1 up, 2, 3, 4, .. down. Exactly the same as my '76 Jawa, actually.
And some rear sets have the shift lever directly on the engine's gear shaft, but with the lever pointing backwards, automatically giving that shift pattern. But the pics I looked at suggest the Scorpion Sport uses a push-pull bar, as seen in other road going sports bikes, thus maintaining the common 1-down shift pattern.
Postby rd400racer » Tue Sep 17, 2019 6:46 am
Here's what I'm dealing with...
rd400racer
Postby millgreen » Tue Sep 17, 2019 12:20 pm
RD, pm me with a cell # and I'll send you a pic of what I've got, have some parts from older Skorpions.
Bill
millgreen
Return to Wanted
